Hello,
I am putting up a set of shelves in a deep alcove between chimney breast and side wall.
I have cut the shelves to be proper rectangles, and because of the 'wonky' nature of the alcove (ie it is NOT a proper rectangle in plan section) there are gaps between sections of the shelves and the rear and side walls.
They are not large - a few mm at most.
Can I use normal decorators caulk to fill these gaps or will that not be flexible enough? The shelves are fixed to the wall using long strip pine sections against the rear and side walls with the shelf itself sitting on these strips of wood and tacked down.
But there is bound to be some slight movement of the shelves - perhaps some very slight bowing towards the centre and lateral movement when heavier objects are put down on the shelf. So I am a bit concerned that using a solid filler between the gaps will eventually crack and work free.
Should I use some kind of flexible filler, if so what type?
Ideally i'd need to be able to gloss over the filler
