Is anyone able to help?
this is the filling loop on my boiler, I needed to repressurise it this morning after bleeding the radiators. As it has no handle I used an expandable spanner and it slipped off of the knob when I tried to close it on reaching 1bar, o then struggled to get it back on before pressure hit 3 bar. I’m not sure if it’s open or closed now?! If I turn it either way it starts to leak very slowly, but when I have removed lots and lots of water from the radiators the pressure hasn’t moved at all suggesting it’s still open? My overflow pipe outside is also leaking. I’ve switched the boiler off for now. If the loop is still open will the pressure continue to rise over 3? Can anyone advise?
