Morning all,
I'm in the process of moving a radiator and made the mistake of looking under the carpet! Under the loose parquet I found a compression joint partially buried in breaking up screed. Uncovering this led to another compression joint- originally the radiator was obviously where the patio doors are now- so this will be its second move. The trench was full of loose material- I've removed all this and cut back a little to reveal both pipes.
There is what looks like a clear plastic DPM which has gone brittle and is now holed- so that will need repair.
Obviously the compression joints have to go, so my thinking is to joint the copper to plastic pipe in pipe at the last point where the flow and return are together- this keeps the joints down to two in a known area and make them as accessible as I can. The long term aim is to remove the parquet as its all loose, rescreed and lay karndean- I'll be getting a pro in for that.
Given all this- what best to fill the trench with?
SimonView media item 97432View media item 97431View media item 97430
