finding an s trap toilet
3 Nov 2007
I am trying to replace an old toilet that has an s trap into a clay pipe. I can't box the wall off as the room is not long enough so have to stick with an s trap. Does anyone do a version with a close coupled cistern? and if so would you mind posting a link?
thanks
i did have a look at the 90' bend, the swan neck will reduce it slighty more. i think i will ahve another measure up. The rooms so short that i can't afford to put any boxing behind the toilet. thanks
also has anyone noticed any problems when using that swan neck connector? I'm abit heavy with the toilet paper :lol:
With the modern 'Water Saving' 6 litre flush it doesnt always clear the pan on a single flush. Sometimes better to flush midway through the operation then flush again when finished. 6 litres in my experience is not enough to clear the contents of the pan in 1 hit.
Twyfords still make the s trap pans but not sure about cc version
Be careful with the swan neck, remember the base of the pan will hit the clay pipe so sometimes its no better than a 90 degree one.
ive had a measure up and the toilet will still be 160mm off the wall even with that swan neck.
Now i have found some CC s trap toilets on the net. most have something desribed as a rough-in. its a distance say 250mm. does anyone know if this is some relationship to how far the pipe exits on the bottom?
cheers
