Hi all,
First I will explain my fuse box - it has a main switch to turn everything off and two rows of fuses, the 2nd row has also a breaker switch at the end which can turn off only the 2nd row without affecting the 1st row.
Now everything has been fine, no changes to electrical installations, no additions and then one day, plug in the vacuum and it trips out the 2nd row breaker switch (not sure of correct terminology) for the 2nd row of fuses in the fuse box. Everytime the vacuum is plugged in/switched on (in any socket) it trips out. What makes it more tricky is that now also the outside path light switch I have noticed does the same, switch it on, the breaker trips out.
Now does this mean the fault is somewhere connected with the bottom row of fuses (sockets/switches etc) only or can be anywhere in the house? The outside light is on the 1st row for example.
I hoped to try a method of find and seek by elimination but when I turned off all but the sockets and this breaker and plug in the vacuum the breaker still went off. Surely if nothing else is on, only the breaker and socket fuse then it must be something with the sockets?
Or could it be that outside in the path lights there is a connection problem (perhaps water in one of the lights?) - would this affect this breaker even if the fuse for these lights were switched off?
Before I start undoing every socket, switch and appliance I thought I would see if anyone had other ideas?
Thanks.
Thanks.
