Fireplace fitting - can I put hearth on oak flooring?
29 Oct 2006
I've just had a solid oak floor laid, and will have a fireplace delivered shortly. The question is, can I lay the granite hearth on top of the wood flooring? I would guess it would have less stability than a solid floor, but it would be a huge issue to have to cut out the wood to accomodate the hearth.
Many Thanks
This would allow you to cut through the floor boards so you could let in the hearth. Its a vibrating tool.
Many thanks for the reply. I'll certainly keep that in mind should I need to take that course of action.
However, would somebody be able to tell me whether I actually need to do this, or whether it is safe to fix the hearth on top of the oak flooring?
as long as the hearth is make from a non flammable material then there should not be a problem. Might have to build up the inside of the fire cavity to match the top of the hearth though.
From what I've been reading recently, I am currently installing one myself, it would be a bad idea. The heat in the hearth stone can make the wood flooring tinder dry creating a high fire risk should any embers get on it. Depends if you're using a soiild fuel fire (then cut the boards out) or gas (no need to bother).
The choice is yours...
