Fitting Bath Screen to a non vertical wall.
16 Mar 2014
Aberdeenshire
Help!! My wall is out by 60mm from top to bottom of the screen. Are there any fittings you can buy to compensate for this, or do I have to botch it?
most come with a profile that the door slots into, this allows for some tolerance.
If you read the specs they will tell you the tolerance allowed, 60mm is a lot though. you could build out a nib that is level
Couldn't find any manuafactures that covered those tolerances. So I built out a nib and it looks ok. Thanks for your thoughts.
