fitting extra rads ?
27 Apr 2009
Essex
Hi all,
I will soon be adding a conservatory on the back of my house.
where I will be fitting the door into it from back of the house
I will have to remove a rad. I am wanting to use the feeds from this old rad to feed 2 in the new build. What is best way to do this?
will i need to supply a send and return to each rad "one each end
of the room"or can i supply one then feed the 2nd with the output from
the first and then via that back to the return ?
My heating system is a Baxi combi 80 closed system
Also:
will plastic quick fit pipe system be ok?
I don't want any pipes showing, can i bury them within the slab base?
Many thanks for your time :D
Paul
flow/return to each rad
if you really have to use plastic you can.
i useally fit a ducting in screed floors for the pipework.
