fitting new shower, what to go for?
16 Jul 2009
i probably shouldnt be thinking of this knowing im not at all tech minded with plumbing and electrics... BUT ... i have a combi boiler with a poor hot water flow rate so mixer taps are out the question.
I do have an electric shower already on the wall but it looks like something noah might have left behind after building the arc!
Its not very good to say the least, it either gives a fierce cold shower or a trickling hot 1. (when i look underneath it does say output 0 bar - if that helps?)
Anyways.... been looking at cheap ish alternatives. Been told i have to get 1 with the right KW rating for the breaker. How do i find this out? any suggestions for very cheap replacements that might actualy do half a job?
thanks in advance (sorry if im a bit thick)
What makes you think the flow rate from the boiler isn't any good? What make and model is it and how old is it?
flow rate from the boiler isnt any good because the hot supply takes a couple (maybe longer) of mins to fill a bucket.... yet cold is done in seconds.
Boiler is a sime freindly format 80e ... (no idea of the age)
:S god knows what make the shower is... its just got a big GbV on it
Can't help but think your boiler needs some attention - others on here will no doubt comment in due course.
As for an electric shower, think your best bet is to get a couple of electricians round for independent advice regarding the state of the current wiring and any recommendations relating to an upgrade. It really isn't possible to provide and further details on here without more specific information. You could try putting a related post on the electrics forum, but I suspect the answer will be not entirely dissimilar.
