fitting outside lights with a switch ..HELP PLEASE
2 Jan 2012
Sussex
Hi all,
first post so be gentle..
i want to install 3 outside lights to all work off 1 switch, is this possible and a "how to" would be great.
i have easy access to the lighting ring.
thanks in advance
Yes it is possible.
You need a feed that you can take phase, neutral and CPC(earth)
Cable that is suitable for current rating of circuit and environment that it will be routed.
If you look at Wiki Projects you will find some useful advice.
Not only on methods of installation, safety but also requirements and law.
I would start here to look at the configuration of the circuit you require.
http://www.diynot.com/wiki/electrics:lighting:single_way_lighting
http://www.diynot.com/wiki/electrics:lighting:parallel
Once you have had a good look at those and got some understanding on how this circuits works, come back and ask questions.
Otherwise you will get told off and hunted down by the big bad wolf :wink: :lol:
