Fixed Shower Head - With combi?
16 Feb 2005
I'm considering getting a Mira Combiforce 415 mixer valve to work with my Vaillant 831 ecotec plus Combination Boiler.
Ideally we want a fixed shower head coming down from the ceiling and are considering getting an 8" fixed shower head.
I've been recommended that i should not use that shower head with my combi boiler.
So been recommended to replace the Mira 415 for the Mira Discovery BIR with a wall mounted Fixed Head and replace the wall mount with the Hansgrohe Ceiling Mount tube.
What does everyone else think? is an 8" fixed head no good with a combi?
thanks a lot.
Seen several 8 inch fitted with no problem. I Have a 7 inch one myself :lol: which is perfectly ok on a 28kw combi and water delivery is more than enough.
Some of the heads although they have 1/2" connection they have a small hole within which is easily drilled out
Seen several 8 inch I Have a 7 inch one myself :lol:
have you now.
I have a 6 inch head which gives a decent but not brill shower with my combi.
Think you will have to try it and hope you get enough flow to satisfy you. :D
