flashing LEDS on my hotpoint wt540 HELP
20 Jan 2011
London
Help please i turnt on my washing macine to find it had stopped working and had 3 different LEDS flashing 1/ on/off 2/wash enhance 3/ rinse hold i presume this is some kind of error code does anyone know how to diagnose or fix this problem any help much appreciated
Scroll down to the bottom of this page & check out "similar topics", your issue has in all probability already been answered there.
If it's 2 and 3 it's not a error code. Unplug it for 2 mins make sure connection on pcb are good.
thanks for taking the time to reply to my post the LEDS that flash are 1 and 3 and the on/off my post is a bit confusing as i haven't explained very well
Error code f 10 check filter. Blow down presure switch check connections on pcb. If all ok new pcb req.
i have error f10 does anybody know how to fix this problem and could they please advise me im not to clear on where to find the parts of the machine which i am meant to check i've taken the lid off but thats as far as i got. Where is the pcb located and what does it look like, also the filter where would i find this and what does this look like. Big thanks to rocks been extremely helpful so far :D
Presure switch is at the top back left hand side or front right depending what drum you have. It's a round plastic thing with a pipe going to the bottom of mc. Disconnect pipe and blow down it. Filter is either under the kick strip at the front or at the rear remove rear white cover it's a black cup under the drum with a jubilee clip round it , clean it out. Then check the pcb back right hand corner down the bottom make sure connections are tight. If still mo joy pcb gone.
