Hotpoint Aquarius WT540 "Extra Rinse" Flashing Fau
14 Sep 2011
Manchester
My Hotpoint Aquarius WT540 "Extra Rinse" (LED 5) is Flashing.
The machine won't switch on/off from the button.
On the previous wash the "Extra Rinse" lamp had been illuminated continuously and the cycle failed to complete.
The manual:
http://airkooldomestics.co.uk/resources/WT540.1P.1G manual.pdf
shows this code as "not applicable"
I've cleand the connections on the switch & LED panel and on the power PCB.
I've also changed the Capacitor C17 as a precaution, but nothing has changed.
I'll have a look at the door switch
Any ideas would be gratefully received.
Disconnect the lead from the consol panel and unplug from the wall for 5 mins.
I did actually do this the other day.
It seemed to work, but then failed to complete the wash cycle. The same problem has recurred.
There must be a fault somewhere.
Does it stop after a certain time. Does the on off light flash as well. Does water enter when put on rinse only prog. That no 5 light flashing on its own is not a error code.
I have just disconnected and re-connected the switch/LED board again.
The machine is now working again.
I have also cleaned the door lock connector contacts.
I have started the machine, but I suspect that the machine may not complete the cycle.
What could be causing this need for a 're-set'?
Who knows. One of life's mysterys. Static electricity spikes from airwaves micro waves. Same as a reset on iPhones sky / virgin boxes iPads computers etc.
Ah yes, but this machine has been working fine since 2006.
It has begun failing in the past few days.
Getting old poss. There's been no answer to these faults. Pcb goes corrupt poss.
