Flatmaster PIV (Positive Input Ventilation) System Location
4 May 2015
London
I'm trying to work out the best place to put a flatmaster PIV system in a lower ground floor Victorian flat.
There's currently a small window above the front door so I'm wondering if that should come out, however I don't really want to lose the light.
See attached image, suggestions welcome. Pink line around shows external walls, windows are pink also.
Thanks[/img]
That guide seems geared towards installing full systems during a build which have ducting built in (hidden) everywhere and ventilate into every room.
I'm talking about adding a flatmaster to an existing (older) property.
The flatmaster just outputs into one area, so I want to know the best place to put it with the layout of the flat I have i.e. where to suck air from (presumably too noisy to have the box in a bedroom) and the optimum place to deposit the air, without having too much visible ducting everywhere.
I just wondered if anyone had any experience with this or any ideas.
