Foundation cement mix
23 Jan 2003
Going to be repairing the foundation (above dpc level on my 1910 Victorian flat. I meed to re lay 2 courses of bricks directly underneath my back door.
Is the 1-3 cement/sand mix ok? Do I need to put any additives in?
You could use a mildly hydraulic lime instead of portland cement. This would blend better into the existing work and if your bricks are soft reds, they will be less likely to get frost damaged. The mix ratios are different but it's easy stuff to work with.
