Freezer not as cold as should be
12 May 2007
My daughter left the frezzer door open for about 24 hrs so all the food was disposed of. I turned it on a left a few days and then put some food inside, although most of it is frozen, it does not seem as frozen as it was before or as cold inside the freezer. It is a 15 yr old Electra upright frost free freezer and has been no problem at all so far, anyone any ideas as to the problem. All the seals are ok, is there a gas that could have ran out??, don't want to buy a new on if not needed.
If it is frosted up as a result of the door being open, it will not get as cold.
Defrost & start again, then report back.
The gas wont have gone because the door was open.
"Frost Free" freezers have air channels and drainage pipes in the back concealed behind the lining, where the frost is accumulated, then melted and drained away. If the door is left open with the compressor running, the frost load will be too great for it to cope with.
It is quite common for these to become choked with frost and ice, after which the freezer will not work properly. Once clogged, it will no longer defrost itself, nor will it chill properly.
Unplug it (so the compressor is no longer running), empty out all the food and eat it, and leave the door open for 24 hours. You will probably find a surprising amount of water dribbles out into the cabinet, and into the drainage dish at the back (if you pull the freezer away from the wall you can see this drainage dish and swab it out to remove mould, grime and so that excess water does not drip onto the electrical parts).
When it has stoped dripping, mop it inside and out with paper towels so you are sure it is dry, leave it another hour to make sure there are no more drips inside or out, then close the door and plug it back in.
Knowing how to remove frost blockages can save you the expense of buying a new freezer. It is absolutely essential that you leave it long enough for all the interior frost and ice to melt and dry out.
I would suggest a FULL defrost.
If its frost free, it may well have problems if it ICED UP.
Just to add IMO it could take as much as 3/4 days to fully defrost the drain, if it has not fully defrosted the water that drips from the evaporator when defrosting will just sit in the drain and then freeze up the evaporator when appliance starts again.
As said if you find water in the drip tray at the rear you know the drain is clear.
Good luck
Colin
