I hope someone can help me please!!!
I have a semia condens f30e combi boiler and from what i can tell I have 2 problems, I don't know whether they are related or not?
Ok story starts off with my heating not coming on. So I climb up in the loft and the boiler has a flashing red light and error code 01. Which according to help line is to do with the pressure. Thing is the pressure dial was already at the top of the green so I didn't want to add anymore in. Instead I went round and bled every rad to make get rid of any air and bring the gage down.
I've tried resetting it and I can see that the flame takes so I know it isn't to do with the gas. The temp display starts rolling up and gets about 8 degrees higher from where it was and then stops and displays the same error again.
I had a look n feel underneath and at the back lefthand corner there is a plastic ridged pipe and a plastic cylinder type thing and it looks to be dripping.
Does this ring any bells with anyone? Any guesses on what it will cost and if anyone out there is available I would be interested in hearing from you??
Thanks in advance
Thanks in advance
