Well my family has brought a new house recently and we have a problem.
When ever the heating is off, and we want hot water, the boiler does not fire and cannot diliver hot water to us. So whenever we need hot water we wouold need to switch the heating on, so that it fires and there is hot water.
the pressure on the boiler is 2.0
and as it said on the user guide, if there is heating but no hot water, check that the hot water tap is giving 1paint/10second and my hot water tap is giving about 1.5ish paint per 10seconds.
so please can you help,
The boiler currently installed is called ideal C80FF
the manual can be found here:
http://www.idealheating.com/downloads/manuals/152317.pdf
And the user guide:
http://www.idealheating.com/downloads/manuals/155553-1.pdf
in addition to the boiler there is a timer called switchmasteer SM300 which in rite next to the boiler. It has a dial with 4 pegs which can go in and out. Next to that is a switch with 3 items
Timer
Off
Constant.
i could not find the manual, sorry
And to switch the heating on we just put the switch to constant.
there is also a room temperature control which is set to 27ish degree's
And the user guide:
Timer
Off
Constant.
