frost protection
3 Mar 2008
Gwynedd
I've been asked to help with shutting down a cottage for winter. I don't know if i need to drain an indirect water cylinder. Are these cylinders and their associated header tanks vulnerable to frost damage? On the same train of thought, is pvc water pipe as susceptible as copper to cracking as a result of freezing.?
I'd love to hear people's thoughts .
Insurance is likely to demand all is fully drained down or background heated 24/7... 12-15C is common minimum stipulated... check the Insurance paperwork.
* CH boiler/rads with suitable levels of antifreeze might be OK (needs check with Insurer obviously). The late in-Laws had such in a static caravan where the site disconnected and drained down potable water and also the electricity was isolated at distribution centres (bottled LPG); so fridges needed emptying out as well.
Fernox Alphi11 is a combined anti-freeze and corrosion inhibitor and will stop the entire CH circuit and its header tank from freezing. It's not cheap when purchased from the usual high street plumbing suppliers but good prices can be found online.
