Galaxy G2-44 keypad options
2 Nov 2013
Buckinghamshire
I have recently purchased a galaxy G2-44 for upgrading a friends old optima system. The keypad menu (58) doesn't seem to be there meaning I can't setup the keypad backlight to be off when the system is set. Can this be done on the G2 range or am I right in thinking it can only be done on the G3 and dimension series? Thanks
Didn't think so. Thanks. Can the keypad buzzer have its output type changed under 53 program outputs or is that also unavailable on the G2?
Also unavailable on the grade 2.
You can turn the keypad down via the pot on the CP038. Use the night set to ensure silent night setting operation.
Not many have multiple keypads fitted, end up using the IP based phone apps instead of having keypads in bedrooms.
