Hello,
Back again needing some help relating to my lockshield valve fitting.
Come across one radiator in my house which has a stubborn old fitting which I am unable to remove with grips.
Any tips on how to ease the removal? It was fitted with paste and fibre donkeys years ago (I removed some of the fibre under the joint, this worked on other radiators enough to allow some "give" on the joint). I was wondering if I used a heat gun to heat the joint would that help or be a risk?
