If this should be in the Garden section, or another, please feel free to move it.
I have two questions about some touch-up work I'm doing on my flat-roofed / rendered wall garage. This is question 1 of 2 - the second concerns the flat roof (which I'll put into the Roofing section).
Firstly, I have started to paint the wall and it's looking OK, but I have noticed that there is a gap between where the wall ends and the tiles / slabs on the outside of the garage start.
I think that water is getting in here in bad weather because at the other side of this wall inside the garage it is sometimes wet.
I would like to attempt to seal it better on the outside.
My first thought was to use what is put on roofs - lead flashing... but I doubt that would look very good and it's probably expensive?
So I was looking through the Screwfix catalogue and there's various sealants I could use... there's Dow Corning for sealing windows and frames, there's Geocel Trade Mate for draught proofing, there's No Nonsense Builders Silicone Sealant which is fungal resistant, weatherproof and UV resistant, there's even bathroom type sealants which come in an off-white colour.
But there's also something called Flashband on page 113 - this is said to be a "lead replacement" and looks like it comes on a roll of tape in various widths.
I'd originally envisaged a strip of product bent at a 90 degree angle that I could lay down at the side of the garage and either adhere to the wall and floor, or screw in, thereby stopping water going into the gap. I can't seem to find out what that might be.
Can anyone recommend what product I would be best off using if I wanted to try and seal this gap between my garage wall and the paving slabs?
Is it 1) a sealant, 2) a tape or 3) a strip of some more rigid product designed as a trim for this kind of thing? Or is it 4) something else?
Any advice appreciated.
