yep that sounds good.
you could just use a linear aco type channel rather than the interceptor arrangement.
Yeah we did think about that but the missus overruled on aesthetics!
Sticking with the interceptor arrangement, what type, and diameter, pipe would you recommend - 80mm plastic?
How deep should we lay the pipe? The higher ground area that is being drained is approximately 90m2.
And how would we connect the drain to the surface water drainage system (i.e. the pipes in the second picture in my previous post), given the significantly larger diameter of these compared to the smaller land drain pipe?
