Did a search of the forum and it appears if the manufacturer allows it then a flxible hose can be used to connect the hob to the gas supply. I've had the gas pipe installed by a CORGI man and he has blanked it off the end (about 40 cm from the hob fitting). I was expecting to fit the flexible hose myself unless it's a no-no.
Q. What type of fittings will I need on the flexible pipe - hob appears to have a male 1/2" thread (probably metric). Hob manufacturer is Stoves.
