gas rates
13 May 2008
Berkshire
soon to be taking my acs and entering the gas world. need some input on gas rates. appliance gas rate is under the max pressure.
1) check meter working pressure 19-23mb
2)inlet applaince pressure. no more then 1 mb below that recorded for meter working pressure
3)if above is correct would i be looking at blocked filter on gas c
valve, blocked burner injector, on combi's low DHW flow rate, on premix burners they determine amount of gas entrained so look at this,
have i got it right?? would failing boiler stATS AND THERMISTORS cause low gas rates?ie poor thermistors = poor voltage to modureg=low gas rate??? have i got thid low gas rate fault finding prodedure right????
Depends on the boiler, etc etc. Better asked in te Combustion Chamber perhaps.
