I'm having weird problems with the above boiler. In short whenever it's used water starts draining from the pressure relief valve until i's gets to about 0.6 bar. However the actual pressure never even goes above 2 bar (the valve being rated at 3 bar).
Some random things I've found through playing around:
I've changed the valve and both valves has exactly the same problems.
The valve itself doesn't leak unless the boiler has been used, for instance once I've refilled the system it'll happily sit there and not leak anything all day long so it's not even a constant problem.
When the heating is off it empty's faster. For instance we can have the heating on for several hours and it'll work until turned off; use the heating for only an hour and it'll empty itself within 10minutes once turned off.
Anyone got any ideas what could be wrong?
