Glow worm 24cxi & Programmable Thermostat Wiring
1 Nov 2010
Middlesex
Hi All,
I have a Glow Worm 24cxi combi boiler and wish to wire a programmable thermostat to it. I have a 3 core cable connected to the thermostat (Heatmiser PTR - mains voltage) - the L, N and Switched Live are correctly wired.
But how do I connect these to the boiler. Now I know where the switched live connects in the boiler but where do I connect the L and N so that I can have power going to the thermostat.
The instruction manual for the boiler is pretty rubbish.
Boiler Manual
http://www.ultimatehandyman.org/PDF...0-38-Cxi-installation-manual-47-047-24-27.pdf
Thermo Manual
http://www.heatmiser.co.uk/manuals/prtv3.pdf
Any help would be welcome.
Cheers
Am I misreading your post?
You take the L & N from the fused spur and provide a switch live to the options board.
Sounds too simple, am I missing something here? :shock: :?
It does sound simple. But I need to get the L and N from a point within the boiler. It's just that I can't find those points within the boiler anywhere...
You don't get the L and N feed directly from the boiler for the thermostat. If you took the time to read the manual diagrams instead of slating the manual off you would clearly see that you take the L and N feed for the stat from the fuse spur and run a single switched live to the 230v control board. Don't go blaming manuals when you haven't been arsed to read the damn thing muppet
You don't get the L and N feed directly from the boiler for the thermostat. If you took the time to read the manual diagrams instead of slating the manual off you would clearly see that you take the L and N feed for the stat from the fuse spur and run a single switched live to the 230v control board. Don't go blaming manuals when you haven't been a***d to read the damn thing muppet
Well I would like to say thank you but I shall refrain.
This is a DIY forum where users come for help. Now if you feel that it is above yourself to provide this help without being abusive, may I suggest that you don't 'waste your time' in reading these posts and responding.
I see you have only recently joined and have zero thanks - I suspect it will stay that way.
I'd also like to point out that your information is also incorrect. If I have a 3 core lead going from the boiler to thermostat, then of course common sense tells me the L and N come from the boiler.
For the others on here can I ask a final question. I presume that it is ok to take the L and N connection for the heating controls from where the fused spur wire connects into the boiler?
Thanks in advance. :wink:
Thermostat Manual Page 20 Voltage free switching connection A1 and A2 by the look of it. To the thermostat connection in the boiler next to the live neutral earth connection in the boiler underside on the left.
I'm confused.... Is that not what i said in my post?
As for the incorrect info... You stated "common sense tells me to take the L and N from the boiler"... wether or not "your common" sense tells you that the manual states different.
As for the "abusive" part... Muppet is hardly an abusive term, you slated the manual off when the diagrams are nice and clear! So there for the term muppet was highly appropriate i think! :D
As for the receiving thanks part. i am sure in time i will get thanks from people who genuinely are stuck and not the case where the can't be bothered to read or understand a manual! This is indeed a help forum however if people cannot read or understand a wiring diagram then there is no help available there!
To sum up
1. Read the manual before saying its rubbish
2. Don't try and ask a question, then upon receiving a reply say thank you and also that i am giving incorrect advice?!?
3. Take the time to read the manual again
4. Don't listen to your "common sense" it clearly isn't that bright!
5. Don't bother trying to come back with a witty remark to this becuase i am the proud owner of 1001 work related witty insults and come backs!
Good day sir
Yes recently joined and so far zero thanks...still better than 7 months and nothing!
