Hi everyone,
I've got a problem with my glow worm boiler (similar to other people on here it seems
The hot water will run for a couple of minutes, then go cold for a minute, then hot again, so on, so forth.
Strangely the radiators seem to come on at the same time, even when the thermostat is down to zero, the rad temp on the boiler is down to zero, and the heating is switched to off.
I've checked the taps in all the rooms and bizzarely only the upstairs taps/showers are effected. The kitchen, downstairs loo and outside hot tap (yes I have an oustide hot tap, don't ask.....) all run fine.
My initial thought was the diverter valve. Had a guy out to look at it and he changed the cartridge, but no avail. He's quoted £400 to change the valve in its entirety (which seems a bit steep to me).
Any suggestions?
Thanks in advance.
Any suggestions?
Thanks in advance.
