Glow Worm 38cxi combi boiler
11 Apr 2010
Yorkshire
Can anyone help with my boiler. It is flashing F then 13 (which I'm guessing could be Fault Code 13). The pressure was down to .6. I have got the pressure back up to 1 but the boiler still won't work. I have switched it off and switched back on but nothing and still flashes F then 13. Any help would be much appreciated.
dont know the boiler but does it have a reset button maybe a flame with a cross through it. is f13 a low pressure fault check your install manual.
Nath
When the boiler getds older and particular;y if the water is a bit dirty it takes some time to reset.
For a start reset the pressure to 1.5 Bar.
For the future make sure you check the boiler pressure regularly!
Do you wait until your car tyres are flat before repressurising them?
Tony
