Glow worm compact 80e dripping water from inside.
19 Mar 2013
Bristol
Hi i wonder if anyone can help. I have a Glow warm compact 80E which has started leaking from inside. The leak seems to be coming from the hot water out pipe and gets worse when the heating is on. Any ideas as to what is causing this would be greatful. Will try and upload an image if i can.
Pat [/img]
Well obviously something is leaking.
I cannot see very clearly from your pictures and I expect it will need an engineer at the boiler to identify the problem.
There has been a long term leak from the left hand pipe which does not seem to bother you.
Tony
Hi tony, thanks for the reply, yeah that leak was sorted months back. This new leak only started a few days ago. From looking at the diagram it seems to be coming from the domestic hot water thermistor.
