Glow Worm econ 40:burner run for 5mins ?
28 Oct 2006
Manchester
After the enevitable start up after the summer my system has the following problem:-
we have an old style pumped system with hot water tank. A local plumber looked at the fault and just said it a wiring fault and left. The system had run okay for 6/8 years with no issues so i doubted the advice but then set about tracing the system.
I've swapped the y valve and replaced the pump.
The the pump runs okay on the cyl stat and the burner fires from cold. but only runs for about 5 mins. ive checked the over heat sensor on the outlet and the cct is made. The solenoid is energised and the thermostat in the boiler seems to switch okay
i now suspect the gas valve which must have some kind of flow sensor
I assume that fitting a new gas valve, is a Corgi fitted product just looking for some intelligent comments for a vaguely technical DIYer
i do have the orginal service manual with the Gas Council parts lists
:evil:
Maybe some other blockage restricting the flow
Flow sensor in the gas valve ?
I doooooont think so
thanks for the comment
okay but the hot water gets upstatis to the hw tank it just shuts down after 5 mins. I suspected the flow when i changed the pump. How do i check water flow at the boiler? the pipes are stashed away is the flow sensor on the valve or in the boiler housing ?
Sorry raden just re-read your comment
My assumption was that ther was some kind of flow sensor
the logic was this :-
Pump runing
thermostat made, solenoid energised
thermal cut out Made (fail safe I assume)
just looking a reason for the burner to fire initially and then shut down
Problem sorted:
Got local man: R+B plumbing and heating put a new valve and all is rosy. Still not sure as to why the origianl valve would only run for 5 mins (solenoid stil energised and not overheating) but everthing is toastie now.
:lol:
