glow worm swift flow 80 sit combi boiler
13 Oct 2009
Cardiff
I've a few niggles with my combi boiler at the moment:1-The shower water keep flunctuating in temp.2-The temp.of hot water is scalding+3-The boiler is making a screaming noise when heating is on,can someone please help?
I'm going to take a wild stab in the dark, and go with scaled heat exchanger slowing down the water causing over heating.
The screaming noise may be either the pump or the fan, the only moving components within the appliance. More likely to be the pump as the fan would be running at full speed while you are trying to get some hot water.
Good luck with that, Smithy.
