Gloworm Ultimate
5 Apr 2008
Kent
Ignition firing but not lighting boiler. Continuously repetitive firing/clicking but pilot not lighting. Overheat button is fine i.e. pressed in. Water and rads, cold
can you see a spark. common prob on these is shorting of ign lead to case where it goes through casing
Check ignition lead as above. If you do it in the dark you may see the spark arcing to earth on the case.
