glowworm 24ci problem
25 Oct 2007
Leicester
hi my boiler keeps losing pressure no signs of leaks anywhere. keeps dropping down to around 0.5 bar flashing red no fault code showing. When i try refilling as soon as i turn the tap water leaks out from under neath any ideas what is causing this. thanks
Have you checked the pressure relief valve, to see if its letting by. The pipe that goes outside.
When you refill it's normal for water to come out, it comes out a small nozzle that looks like it should have a cap on it but glowworm say that is how its supposed to be.
James
ive not noticed any water leaking outside down the wall. its not to bad if you keep heating on permanant only when you have it on timed it plays up every time ie wake up in the morning no heating or hot water and pressure is down flashing red.
