Hi All,
I recently had a problem with my Glowworm 30cxi boiler (leak) and had to replace the Left Hand Hydroblock(Sanitary Block). After replacing this part everything seemed fine for a few days then the CH pressure started to drop until the boiler became inoperable. Everything started working again after refilling the system back to 1 bar but the pressure would drop and I'd have to repeat the refilling.
After reading extensively on this site (Thanks to all who posted) I tested and replaced a faulty Expansion vessel (I checked the pressure was 0.5 bar before/after fitting) and replaced the Safety Discharge Valve (PRV) just in case. Unfortunately the boiler is still dropping pressure. I have noticed that a lot of water is ejected from the external plastic condensate pipe.
I'm presuming that the water from the condensate pipe is the leaking water from the boiler but I'm at a loss to explain why it's still being ejected and what I can do to stop it. Can anybody help.
Thanks in advance
Michael
Thanks in advance
Michael
