Glowworm 40FF no heat
27 Aug 2004
My boiler has fired up ok, but there is no heating coming on and the ignition click is still going even though alight...any ideas please?
It sounds as if you are going to need an engineer!
I know that! Just wondered if any ideas what is up with that limited description. It lights about 4 out of 5 times. the odd time just sparks but can see blue flames too, not like when it loud clicks and ignition cable was faulty.
That fault is very common on that boiler and usually a simple fix, but it requires access to the combustion area and as such no advice can be given.
Thanks will let you know what happens BG visiting today.
