House is fitted with a glowworm fuelsaver 50br ( ~ 14 years old) which has been causing some problems over the last few months. First the boiler would not stay lit, so I had it serviced - engineer said it was sooted up so he cleaned it and replaced the thermocouple. Then a few weeks later the pilot light would not stay lit so thermocouple was replaced again - no problems for a few weeks. Then boiler started to cut out a few minutes after firing up. Heating engineer replaced the overheat cutout and again no problems for about 2 weeks. Now seeing the same problem. Pilot light stays lit ok, switch on boiler thermostat, it fires up and then after a couple of minutes cuts out. The pump is spinning ( though its a bit noisy). Now the engineer I have been using is saying that he thinks I need to replace the boiler - but can't tell me what is broken. What should I be looking at, any ideas gratefully received.
Gerard
Gerard
