I've a 1980s Bovis property with composite-stone external window cills. Over the years a crack has formed, giving rise to water ingress and now of course the re-bar inside is rusted, expanded and the whole cill is breaking away. I've removed the loose pieces and released all of the wood-lice and other gunge.
How do I go about re-affixing it all back together please? Ideally I'd have thought some sort of resin glue which I could use to hold the pieces in place and then fill the remaining surface cracks.
Is simple yellow coloured mortar the way to go instead? I'm concerned that the thickness of the mortar would cause the pieces to be mis-aligned from where they should be.
TIA
TIA
