Grit in release valve
27 Jun 2012
Leics
In our hot water solar system we have a "pressure" release valve, although the system is not really running high pressures.
Anyway as the system is 18years old, we had/have some grit from decayed antifreeze in the system. The antifreeze is replaced and clear again and the system was flushed, although the grit probally sits and collected in the small channels of the collector.
The problem is, that a release valve which has never leaked much fluid out is now allowing some ml and a collection bottle is slowly filling.
Is there a way to service / clean a release valve seating or is it a matter of a new valve?
Depends, some release valves can be disassembled and the seat cleaned, seal replaced. Sometimes opening and closing the valve a few times can allow any debris to be flushed out and the valve then re-seats properly.
Invariably though, if it's been in there for 18Yrs, it's done it's job and it's time to be replaced.
