Have to replace a Double Glazed Sealed Unit on a friend's back door.
I would like a guide price as to the glass, if anyone's a clue.
It's the Top half of a uPVC back door.
I assume doors have to use 4mm Toughened glass.
1095 x 745mm x 24mm thick.
Though not the exact size, I'll obviously measure carefully before ordering it.
Do I take a 'tight fit' size and deduct 10mm to cater for the supports and a bit of slack... and is that off both dimensions or is the width less of a deduction.
In fact, is the height or width the first measure when quoting size.
Are seals typically re-used or renewed?
Other than a scraper, white rubber mallet, washing-up liquid [ if the seal is the slip-in kind ] and some patience - do I need anything else?
Ooh! Gloves too!!!!!!!!
