Gurgling noise in a radiator after hot tap is off
1 Feb 2025
Hi, I have a Worcester Combi Compact Boiler recently fitted.
One radiator made a gurgling noise on the inlet side after I used and turned off a hot water tap.
I tried to bleed it and only water came out, but I did found that sometimes the towel rack in the bathroom (Not the same radiator) contains a small amount of gas
Is anyone having any idea about this?
Would it be a malfunctioning diverter valve causing this issue?
Should I call Bosch to check it out?
Attached a video. The sound took place at around 0:07 in the video.
Thanks in advance.
Thanks. So does it mean some air is trapped in the system?
