Gurgling radiators and pipes.
Ash
15 Feb 2004
I recently broke into my central heating system and added two additional radiators down stairs, at the same time I added thermostatic valves to all the radiators upstairs, upon refilling I went around all the radiators and bled them, but even after several goes at bleeding them (without removing much air) I still have gurgling radiators especially when the heating first comes on, any ideas please.
Trun off all except one, run system till noise stops. Repeat with all other radiators. Bleed all other points as well.
I just found this old post after a search.
Can someone explain why this would work, and whether thay also advise doing this for gurgling pipes/rads?
The flow from the pump is dispersed amongst all rads on which both valves are open. Leaving only one rad open encourages water to flow through that rad and to push through any air in the pipes leading to/from it.
