- Joined
- 28 Jun 2011
- Messages
- 3
- Reaction score
- 0
- Country
Came home from a hard day at work to find out the other half is going mad the boiler is playing up it's a halstead ace and the led for the hot water is on
And the boiler is fired up but the central heating is on to start with it was only heating the central heating at the same times as the clock showed for the heating so off went the timer but still the heating is on but no led for the heating so I thought I will replace the timer clock and for five minutes the heating stayed off but then the boiler fired up showing only the green led for hot water but the heating is getting hot and when I mean hot realy hot please someone help as I haven't got a clue what to replace is it the pcb or a micro switch or is it the diverter valve please help have not had a lot of work lately so I'm a bit skint and don't want to wast money on bits I don't need ???????? I would not mind but can not control the heat of the heating because it only shows hot water be used when the tap is not even on.?????????
