Hello, first time on this forum.
I have an Ace High which only fires up intermittently on both water and heating. Sometimes it runs fine all day but more often it only runs the hot water long enough for a quick shower. At the moment its refusing to do both but will probably run fine for a while in the morning.
The flow switch diaphram was changed and the plate heat exchanger was checked and is clean.
After ignoring a demand for hot water or heating for ages it will then attempt to fire up when there isn't a demand for either.
Its been suggested it could be the air pressure switch, blocked venturi pipes, one or both flow switches and everyones favourite, the pcb.
The pin to the primary flow switch doesnt always pop up when theres a demand but when it does it still doesnt always fire up.
Before all this happened the boiler overheated when the wife ran a bath and I could hear bubbling noises at the top of the boiler and water leaked onto the overheat thermostat from somewhere but that hasnt happened again since the plate heat exchanger was cleaned out.
Any ideas would be greatly appreciated because if its serious it may be better to replace it. Thanks for any help / advice you can give me
