Hi there,
I was wodering if there is anyone that could shed some light on to a problem I have with my halstead boiler.
When you turn the Hot water tap on or go to use the c/h ( boiler activated in burn mode ) the boiler ignites fine but will only run for about 30 seconds then cuts off with the red led flashing ignition lockout.
If I turn the mains off & re-set the whole system the boiler seems to go through a self test without any problems until I go to use either the h/w or put the c/h on & then the same happens again, the boiler seems to run for 30 seconds & then go into ignition lockout.
The whole system was brand new 5 years ago . I have had a couple of problems about a year ago with this bouiler but have sorted them out & been fine since. One of the problems was I had to re-solder the whole PC board as there were lots of dry joints. I also had to replace the HT ignition anode lead as this gone open circuit.
Anyway, back to the boiler. Can anyone help, why does it work perfect for about 30 seconds then go in to ignition lockout with the red LED flashing ?
Thanks. Terry
Thanks. Terry
