halstead combie fault
5 Jul 2007
Liverpool
please can you help my boiler (halsteag finest gold) will start up but then it switches to red lock out i can still hear motor running ?. if i switch off then on again it resets but when i turn tap on same again its the same with the heating.
thanks
kop99
What does the pressure gauge read? , does the heating work or does it do this on heating and dhw?
to tomy preassure gauge is on 1,
to icgs
were is the venturi & is it a easy thing to do .
thanks for replys
thanks for replys
Would strongly advise getting a corgi engineer to do it. I do it as part of a service so should be just a basic charge
rob884 said:
thanks for replys
ok thanks
