halstead eden x sbx 30 propane
15 Jan 2009
boiler runs for approx 20 min when hot it locks out with fault ,
signal loss
Isn't it still under the warrantee?
Are you sure the gas supply is flowing properly?
Is it on a bulk tank or a replaceable cylinder ( which might be getting too cold to supply enough gas in cold weather! ).
Tony
out of warranty
bulk tank buried in ground
good gas supply
will run properly if thermostat turned down
To save my valuable time could you look in the book and tell us what those codes relate to?
Tony
If your time is so valuable, perhaps you shouldn't spend so much time on here :shock: :lol:
led 3 & 4 is ignition lock out after 5 attempts.
Could be spark electrodes, gas valve, loose connections, no gas etc etc.
Since it runs for a while before failing a simple non CORGI check would be to see if the condensate trap is clean ( and not frozen up ).
Tony
