There is a ramp to access my house. The ramp levels off at the top by the door and I wish to extend this area by around 800mm, both out from the door and away from the ramp. Basically make a larger square.
The main challenge I foresee is around the handrail. The existing handrail is fairly simple, around 1.2m high with a vertical bar about 40cm below the top bar. Horizontal posts about every 1.2m. I would like my new rail to be similar to this.
The base is only 40cm or so above the ground. The wall of my new base will have facing brick and be two bricks wide. The concrete base it then around 8cm thick on top of my base.
1. Where would I get a quote for my handrail? I know exact sizes I need (anywhere online?)
2. To install such a rail, would it typically sit directly ontop of my base wall then I would place my concrete top to fix it in place?
Does that make sense?
