Hard wood door frame seals
16 Nov 2013
Buckinghamshire
Hi Guys. I've just fitted a new hard wood front door and new frame which I have to say has come out a really good job. With the frame came a set of rubber seals to insert into the pre-cut groove in the frame. I have installed the top one no problem. If I install the hinge side seal the frame is so stressed when I close the door it visibly twists the frame. If I install the lock side seal there is no way I can actually shut the door !!!!
The door is a perfect fit in the frame with what I would say is the correct clearance between door and frame so I can't work it out what is going wrong.
Any help or advice would be greatly appreciated.
Need to adjust door to fit correctly.If seals cause binding door is fitted too snugly.Lock etc should be fitted after seal to ensure correct fit..
Hi Again. OK so I removed the door today. Fitted the seal and positioned the door back in place to see what sort of fit it will make once adjusted.
The door will sit aprox 4-5 mm proud of the door frame and the Yale night latch won't fit flush. I did check the door frame was suitable for a 44mm thick door when I bought it so have now run out of ideas so any further advice would be greatly appreciated.
Hi
Maybe the keeper of the night latch needs to be fitted away of the frame with some sort of packer(should be inside the lock box).
Make sure you have fitted the seals proper way.
Another solution, throw away the seals and fit the brush strip instead?
Think I will go for throwing the seal away and either looing for a different one or a brush as you suggested. The door will look terrible if I mount it 4-5 mmm protruding from the frame and the lock will also look bad so I really don't want to go down that path.
Thanks everyone who has responded, eBay here I come :D
