Has this been caused by heat?
20 Apr 2005
Gloucestershire
It doesn't smell 'funny'
It looks like it's snapped due to physical force, probably when being put into or removed from a socket.
The actual breakage was probablly caused by physical force but I strongly suspect the plastic case was weakened by hot running and/or was simply not of an appropriate standard in the first place.
The wire connected to the live pin looks worryingly thin and the markings also leave a lot to be desired, the only approval markings are CE and CCC, the CE mark is misprinted and there does not appear to be any indication of a manufacturers name.
Though given that it is rated at 120/230V 0.3A it doesn't need to be that big!
But that's is normal operating current. It's adequacy under fault conditions depends on what (if anything other than the circuit's OPD!) is protecting it, doesn't it?
Kind Regards, John
As a follow up, the plug was new when I inserted it in to the socket, and as it was in the loft, remained untouched until yesterday when I removed it.
I've informed the company that supplied them, as I believe they may be dangerous.
Also inform your local trading standards office. Dangerous items like this need to be removed from sale but the manufactures and others making a profit from them will not voluntarily stop selling them. Enforcement is needed.
